Drain and fill ATF for the Edge at 60K with Amsoil OE FE ATF. This is the third D-F (every 20k). Fluid came out pretty cloudy and brown, which was a bit surprising. I might have to move the next service up a bit.
When out of warranty, will you up to their SS ATF? Never brown even with a 66k interval once on my Fit; though I've scaled that back to 40k.Drain and fill ATF for the Edge at 60K with Amsoil OE FE ATF. This is the third D-F (every 20k). Fluid came out pretty cloudy and brown, which was a bit surprising. I might have to move the next service up a bit.
Where do you have the external filter mounted?2002 2500hd 6.0l LQ4
fully built 4l80e with 3200rpm triple disc converter.
3000 miles since rebuild
out/off: 4 gallons Valvoline synthetic Dexron VI, AC Delco pan filter and OG Fram Titanium FS8A external filter
in/on: 4 gallons HPL Blue ATF with AC Delco pan filter and OG Fram Tiranium FS8A external filter.
dropped the pan to clean out break in materials, changed the O-ring on the mag hytec pan dumped 3 gallons in then pulled the return cooler line of the transmission and started it cycling through all gear positions until the fluid coming out of the line was nice and blue. then topped off with the last gallon. shift feel is night and day different, we’ll see if it lasts unlike DEX III that shears quickly.
passenger side frame rail directly under the cooling stack.Where do you have the external filter mounted?
Is this a B&M remote filter setup?2002 2500hd 6.0l LQ4
just a generic filter base. plumbed it all in with -6AN lines. transmission out-> remote filter-> trucool 40k cooler-> back into transmission.Is this a B&M remote filter setup?
Very cool. So pardon my ignorance but could anyone run this on about any transmission? Or is there something unique in your 80e's pump? Or do you look for a filter that has a certain bypass PSI? Interested in this.just a generic filter base. plumbed it all in with -6AN lines. transmission out-> remote filter-> trucool 40k cooler-> back into transmission.
you could run this setup on just about any transmission. i would look for a low bypass pressure filter. i like the FL1A sized filters due to the size and amount of media. large surface area allows for a lot of fluid flow with low resistance.Very cool. So pardon my ignorance but could anyone run this on about any transmission? Or is there something unique in your 80e's pump? Or do you look for a filter that has a certain bypass PSI? Interested in this.
You have a red alternator?
Nice work! I'll be doing the fluid in my 8hp in my BMW soon with HPL green. What metal pan did you use?Complete drain & refill of 8HP70 on Aston Martin.
Drained a little over 9L OEM (LifeGuard 8) in total:
Refilled with HPL Green ATF, Cold Climate, a bit over 10L.
New pan cleared the rear metal undertray (it's a transaxle on this car), so all in all, a good job.
