Originally Posted By: Bill in Utah
Originally Posted By: 3311
Yes, The other factors mentioned all affect engine temperature so why factor them independently. Not trying to argue, it is only my opinion based on my limited readings on the subject.
The system factors them independently because to the engine and oil there is a lot of difference between just temps and RPM.
So if the system looks at x number of RPM (lets pretend 2000 RPM times 60 mins per hour = 120k per hour times 50 MPH would be 100 hours to make 5000 miles. So 120000 times 100 hours = 12 million revs) and at x number of revs the light goes on. So if the vehicle idles at 1000 RPM (I'm trying to make it simple) the light would go on at 500 hours...
I think the oil and engine suffer a lot more at idling then driving down the road @ 50 MPH. Yet if the system only measured RPMs to figure out when the light comes on it would come on much sooner with the driving then idling (which nails the oil much worst then most anything else)
Big difference with load, temps, what temp the engine is when it is driven and how it is driven.
Bottom line,
A system that SHOULD be in every vehicle. GM did an EXCELLENT job with it and if anything should be MANDATORY in an vehicle it should be an OLM. (instead of idiot things like TPMS
and such)
I would guess that it would not factor them interdependently. It would work this way imo, i would take accumulated rpm and factor them (constantly) against the engine temperature.
Let's say at start up the engine temp is 20°f then it would multiply those accumulated rpm by a factor .20. If vehicle is driving down the road (or idling in traffic) and is at normal operating temperature then those accumulated rpm would be multiplied by a factor 1.0. If your towing a boat or hauling a heavy load in here beautiful Fla and your engine is at 220° then it would multiply those accumulated rpm by .8. My multipliers are only guestimates.
I believe only operating temperature and rpm are accounted for.
I have certainly not read any of the sae papers and my my explanation/guesstimation of the algorithm may seem overly simplistic but I firmly believe in the theory of Occams Razor.
I do wholeheartedly agree that the Gm OLM is a fantastic system and should be used if your vehicle is so equipped. I have typically run it out to 200% with a quality synthetic( M1 5w30 without uoa's) and my 04 2500hd is in excellent shape.
Now if I can get the Delo I switched to do that( with the help of a uoa's) I'll be pretty happy.
Have a nice weekend all!
