Originally Posted By: Wilhelm_D
Every filter bypasses some portion of the time, some more than others.
The tears illustrated let less oil through than the bypass valve already does. You're defining this in black and white with less than perfect as a "failure". That means that every filter with the bypass spring off a couple pounds, or with some dirt in it so it's operating less efficiently than when new, or with a pinhole in the media is a "failure". That's completely unrelated to how things really work.
It all depends, but typically filters rarely bypass the media unless the filter is abused and clogged up with sludge. If the oil is warm it's impossible to make the filter byapss open on my LS6 5.7L V8 at red line. Now if I was a fool and revved the engine to red line with cold oil you can bet the filter would bypass.
And have you done tests and calculations that says a media tear of x.x sq-in that exists for 7,000 miles passes less dirty oil then a bypass valve that opens rarely over 7,000 miles? It's a pretty invalid comparison and excuse to accept torn filter media.
You've made it clear that there is a problem in your mind and you wish to lead an anti-Purolator campaign.
You really haven't been paying attention. I'm not "anti-Purolator" ... I'm "anti-failure" driven. If these tears were occurring in Frams, or WIX or Amsoil or ACDelco or whatever ... I would be talking about it the same way I am now.
Also, I currrently have a PureOne on 2 of my 3 vehicles. The other has a Fram Ultra. Also have about 4 or 5 waiting in the stash. I've been big PureOne advocate here for years, and I'm a big fan of the Ultra. But if Purolator can't get their act together I will stop using them.
Others, like myself, would be interested in whether there is a problem in reality, if there is the extent of it, and the cause or causes of it. I am sure Purolator is in the process of looking into it as well.
The overheated rhetoric in an emotional appeal is not a fair, objective, and scientific approach.
Again, if you had been paying attention I've given my engineering analysis what I think the possible "root cause" could be. Unbiased in brand ... biased in what I see. And I can surely bet that this is a Purolator problem. Something has changed in their materials and/or manufacturing process that has made the media fail under use.
Is Purolator looking into it? ... let's hope so. I've emailed them 3 or 4 times about this issue. If they aren't looking into it, then they have the same attitude you do ... that is, it's really not happening because one chat board sees all these failures, and if it is, what does it matter because it's just a "little tear" that's not gonna hurt anything -
expect their customer base and sales. Oh well ...
