Pilkington Glass (Windshields)
If you don't have a vehicle which has a "black box" behind the rear view mirror glass replacement is not bad. Otherwise to reprograming that black box gets expensive.
So far we have seen a whopping 1 that needed calibration it was by an outside shop. The guy that does our shop work hasn’t had any literally to recalibrate because I asked him when we got a ram in that needed cal.
He was thinking it had to do with the glass being installed incorrectly, the piece being put on in the wrong spot etc.
Glass like other parts can be back ordered and hard to get too
Every piece of glass is in theory different. The "black box" needs recalibration-
quote-
If you recently had a replacement windshield installed in your car that wasn’t made by the same manufacturer as the original car itself, you may want to make sure that your ADAS cameras are still properly aligned and functioning properly. On certain vehicle makes and models, if your new windshield wasn’t made by the car’s OEM (original equipment manufacturer), it may not be made to the same specs and allow for proper calibration. As a result, your vehicle ADAS system may be thrown off of it’s original calibration and not work correctly. Alderfer Glass has the ability to determine which windshields will work with various ADAS systems and supply and install them accordingly, working with your insurance company in the process as needed.
A mis-calibrated ADAS can hinder the functionality of important safety systems and leave you more vulnerable behind the wheel. By having your ADAS system professionally recalibrated after a windshield replacement, you can ensure the continued protection of important safety systems like blind spot monitoring and lane departure warning. As the windshield repair and replacement professionals, the team at Alderfer Glass can properly recalibrate all your ADAS cameras to ensure these features are working correctly.
