chevrofreak
The top of the mount was cut off with a 4-1/2" angle grinder to make it nice and straight, and it was attached to the firewall using stainless steel 1/4" hex bolts on top of stainless washers, and on the back side of the firewall there is a 1-1/4" fender washer on each bolt, with a stainless steel lock washer and stainless steel nut. If I could have found stainless steel fender washers at Home Depot, I would have used them...
The mount is solid with very little flexing of the firewall. There is plenty of clearance to unscrew each filter for individual replacement. The hose is just on there to keep dirt out until I can complete the installation.
There isn't quite enough room under the engine cover to run the hoses, so they may run along the edge of the cover next to the air box, then down to the mount. If I can plumb in some hard line, I might go under the cover, then add about a foot to foot and a half of rubber hose for flex.
