Pentosin FFL3 Porsche DCT Fluid / BMW MTF-LT-5 VOA
JHZR2
Staff member
New Jersey
This is a VOA for Pentosin FFL 3.
This lube was discussed in a thread here:
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3589392/DCT_Fluid_in_an_MT?__AKA_is_Pe
With all the details and confirmation that it is appropriate for use as MTL-5 in my BMW 135i. Some time, maybe in the spring or over the winter if mild, I plan to do an MT and diff lube change-out, now that Im closing in on 15k.
I was somewhat surprised that P was there but not Zn. Not sure what to make of the result.
Other than the wet clutch friction modifier, what is so special about this $30/quart fluid? Nationalistic pride? Must use our monopolistic home team supplier for your vehicle always or else?
Can't use a cross-reference list for GL ratings.
One can cool and strengthen a transmission for any target fluid, so the 'euro high power' means nothing to me.
And, if you don't have the PDK 'wet clutch'? Why bother?!
Originally Posted By: JHZR2
...I was somewhat surprised that P was there but not Zn. Not sure what to make of the result.
Many formulators are now using an active phosphate ester product which has excellent anti-wear performance with a powerful anti-oxidant.
It also provides rust and corrosion protection. It possesses good solubility and stability in a wide range of lubricant base stocks.
There is no reason to use ZDDP, an anti-wear/antioxidant, when one can use this single multi-functional additive.
Depending on the dosage levels, this phosphate ester can used as a GL-5 EP additive in differential lubes, or as an anti-wear additive for GL-4 MTF's.
Testing of this ester in various base oils has passed many FZG gear tests.
Because this is the fluid specified by ZF to be suitable for BMW MTL-5, which is correct for my 135i. And I paid much less than $30.
I agree.
Quote:
Do you have suspicion that a lube meant for high powered Euro vehicles with DCTs would be an inferior product?
Noticed that question went unanswered in favor of natonalistic pride.
