Originally Posted By: NavyVet88
Look, what I know is that an engine that has had 210k put on it using QSAD has got crud all over the innards. I ran two oci's of PHM 5w-30 for less than 2500 miles each and the oil was black as night when drained which tells me it's cleaning very well just from that angle. I'm not saying it has rebuilt the entire motor but it has done its job cleaning. Quaker state is a good oil and I'm not trying to discredit that. I'm just telling you of my observation between it and Pennzoils cleaning abilities.
You guys really need to calm down around here. I swear you get your head bitten off for asking a question or making a statement and heaven forbid somebody decides your wrong....
After 210K there was likely a lot use of older API spec'd QS used. I have doubt using a HM with added detergents loosened a lot of the older crud out of that engine. I have no doubt however if another PCMO was used other than QS her engine would be just as cruddy and if QS Defy was used similar results would have been obtained.
I prefer using SOPUS PMCO's and Pennzoil in particular but have used a lot of Formula Shell and green bottle QS and been just as pleased as if I used Pennzoil.
