O.k., got my report from Blackstone. Now how do I post it? It's in PDF form. Thanks.
Quote:
Really? I figured the silicon was from me replacing the oil pan.
Quote:
How come all your numbers are the same as the Univ averages?
Quote:
Does the balance shaft really result in sufficient inertial losses to justify its removal?
Quote:
He typed it the "unit average" not the universal average. Since it is his first oil sample with Blackstone they will all read the same.
Capn': The Universal averages are typically more useful, perhaps it was just an oversight. They put the unit average right next to your data and the universal average at the far right.
Quote:
To my untrained eye it looks like a good report. My only nit to pick would be that the silicon level seems a bit high for only 2,775 miles. What brand air filter are you using on your CAI? If it's an oiled cotton gauze type, you might want to consider ditching it in favor of an AEM dryflow filter to see if you can get the Si down a bit.
Quote:
The AEM supposedly has superior filtration capabilities.
An 02 Spec V doesn't call for 5w-20, does it? The analysis looks amazingly good!
