Here's your stock filter size in Wix. You have a 3/4-16 thread, a 2.7s/2.4x gasket (the majority are 2.8x/2.4x), and a generic bypass valve setting. The rest is physical can diameter and length.
Part Number: 51348
UPC Number: 765809513488
Principal Application: Various Chrysler/Jeep (82-08), Various GM, Saturn (85-07), Lexus (90-08), Saab (67-08), Suzuki (86-02), Toyota (88-08), Yugo (86-89), Harley-Davidson, Various Lawn&Garden, Farm Equip.
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=21/37
Burst Pressure-PSI: 275
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.734 2.430 0.226
You diameter is 3.0+/-" (though 2.9x" is an important distinction from 3.0=/+ in some lines.
If you have no restrictions on diameter or length, there are litereally (up to) 40+ options in various offerings.
FL400S would be a longer alternative.
(in wix)
Part Number: 51516
UPC Number: 765809515161
Principal Application: Ford/Lincoln/Mercury (81-08), Chrysler/Jeep (02-08), Mazda Trucks (94-07)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.828
Thread Size: 3/4-16
Beta Ratio: 2/20=14/31
Nominal Micron Rating: 20
Gasket Diameters
