Originally Posted By: dwendt44
How about changing the coolant sensor?
They go bad too.
Another possibility, install the largest radiator available for that vehicle.
The large size Durango could be had with the hemi engine.
The early version had the 360 as an option.
I really would like to do this, and if this radiator which is now out of warranty would just crack, I could pull all the bits I need from a '98-'99 model with rear air and a 360 and a tow package and go with that. Two problems with that idea. 1) the fan clutch for that is WAY thicker so say goodbye to my brand new thermal clutch. 2) the fan clutch is thicker and there won't be room for my brand new $200+ electric fan. I need to make it work stock first. Then when some of this stuff breaks again I can consider the '98-'99 setup with no electric fan.
I like the ground idea. Was reading about a bad ground screwing with the PCM on these.
Try this, it's crazy: Connect a scan tool OR connect pins 4 & 5 on the OBDII port. (Signal ground and chassis ground.)
There have been durangos of about your vintage getting very wonky due to a marginal PCM ground. If nothing else it might help the logic of the electric fan come on sooner.
Is this something I can do with a multimeter? Voltage drop of more than what signifies a problem? 0.5v? 0.1v?
Originally Posted By: doitmyself
Is it possible the replacement water pump is defective? Sometimes we overlook the obvious in the zeal to "CSI" the problem.
I googled "durango overheating problem" and there are numerous links to pursue.
At Edmunds, their is a long, current thread going on that has many ideas:
http://townhall-talk.edmunds.com/direct/view/.f0dfe3f This will get you into the end of the discussion, but check earlier pages too.
Topics that came up:
Durangos have a 2nd. auxillary water pump??????
Bad thermostat location/design????? And many other ideas. The auxillary water pump replacement fixed the problem for many that did the same repairs repeatedly like you.
Please keep us informed!
I am certain the water pump is working well, cold engine, radiator cap off, you start it and fluid moves a bit and then when the t-stat opens it's a real good flow.
I think that 2nd water pump is for rear auxiliary heat on models equipped. My truck doesn't have this option, only rear air, but I am going to see if I have one of these electric pumps. If it's on the truck, it's probably not inline with the rest of the cooling system due to the bypassed heater core. I could always run the heater core lines back around the engine and utilize this electric pump and just not attach it through to the heater core. Re-bypass the heater core to include the pump. Hmm. Would make sense.
Originally Posted By: mopar_monkey
i've seen many issues with aftermarket fan clutches on these engine, it seems that many aftermarket clutches just don't work right out of the box.
Mopar clutch. Mopar fan. Replaced at the dealer by a dealer tech. Warrantied, even. You can def. HEAR this fan on startup, when warm, when accelerating, etc...and if the hood's open and you rev the engine it's a big wind. Also another poster mentioned is the electric coming on, and you bet it is, I have verified electric fan operation both with AC on (it stays on) and with AC off (comes on a couple minutes after t-stat opens on a cold engine).
Gearhead, I have my own compression tester and this is part of that list of things I mentioned above to do.
Flacoman, this may be the excuse I need to buy an IR thermometer and find out where the hotspots are.
Warstud, hooking the core back up isn't something I want to do, if only to avoid a wet carpet inside. Besides, with a loss of pressure I risk boilover even with good coolant mix. You have to have the pressure to raise the boiling point, too.
Skid, you know what, this fan DID look different after installed by that dealer. The question is, is it backwards now? Or was it backwards before? Or am I seeing things?
meep, I'm going to the impound auction in the morning. 27 vehicles to choose from. One is a '99 Sunfire with keys, title, good tags, good inspection. That might be a good beater to bang around town in. Also, I'm willing to put my bet on that front AC expansion valve. Why? Because it's probably shoved up in the dash with the heater core where I can't get to it.
Originally Posted By: Hokiefyd
If you run the front A/C in recirc mode, does it cool better and/or not heat the engine up as much?
Kind of and not really. I can barely notice a temp change when on MAX. Have to have the windows closed to feel it. The engine will heat up just the same. Been doing that over the last 24 hours and it gets just as hot and the AC up front still doesn't cool very well. For as cold as the back gets, it's weird that the front doesn't.
morris, I'll check this thermostat and see if it has a weep hole...it's been changed a couple times now, Texan4Life, and there's a definite "it's not opening...you sure? yeah, nothing, shouldn't it have opened by n....oh...look here, it's open now, quick put the cap back on before my wife sees this mess on the driveway" kinda thing going on.
Bladecutter, if the AC is pressurized too high, wouldn't the lines freeze up and have frost on 'em? Or is that for a low charge?
