Originally Posted by JTK
Originally Posted by glock19
...The only concern I have now is for the transmission, it's definitely going to be exposed to some hilly terrain.
As long as the operator doesn't weigh a ton and you mow high like you say and you don't try to cut grass that's 6" high, it should last. Like said, keep it running it's coolest by blowing the crap off the trans housing after each use. Changing the oil on them doubles or triples their lifespan too. They are sold as "sealed", but the oil can be changed on them.
Thanks for the reassurance. I weigh 170lbs and I'll only be mowing dry 4.5" grass down to 3.5" so I don't think it's going to be too much of a load. I'll have to look into the procedure to change the transmission fluid.
