Old school 10A battery charger, needs transformer
Jupiter, Florida
I have a smoking transformer in my favorite battery charger. You know the kind of old, unregulated 6V-12V charger where it produces about 8-15V open circuit at the leads, and the leads spark nicely when touched. It will push a charge any 12V battery, of any size, even if the battery is so dead it reads 0.000V.
I tried to purchase a replacement charger from HF that "seemed" to be nanny free, but it too has the electronic nannies that prevent it from working for my needs.
I want to purchase a replacement transformer. Any thoughts on where to get one?
Yes, I clearly understand that dead batteries are useless. But I use this to open my driveway gate when the batteries fail and other emergency uses, such as when the wife leaves the headlights on for a week. That kind of thing. The other one won't do the job.
There are new chargers that will charge a battery at 0V. You do have to push a button to get it to work.
I would look for numbers on the transformer and start googling.
Check Goodwill stores, Salvation Army stores, or garage sales. Another thought would be to go to a ham radio "hamfest" and go through their flea market area.
Here is my old school unit which has a 15 amp setting plus a 100 amp “ engine start” setting. I still usually use a smart charger but it’s nice to have this bad boy around. The only “automatic” feature is that it will turn off when the battery is fully charged.
sounds like it's as hard to find as a left-handed monkey wrench. Harbor Freight had it on sale but when I went to the store they told me everyone else wanted one and they only had 6 to begin with
If I need a battery charger to charge a completely dead battery, I use a variable power supply:
I can put 16V into a dead battery to try to get it to charge with one of these. I can also limit the current for charging smaller batteries.
Better yet would be a current limited 14.4V power supply. I have one for similar purposes, limited to 5 amps. Works great for almost 20 years now.
I got this for $125 during the pandemic. I tested it and drew as high as 35A when connected to my car with headlights, defrost, and blower on. It really did clamp down on the voltage, stays at 13.2v or so. It was 13.6v when the draw was low. I think of it as being similar to a device in a car dealership when they let you sit in the car with all accessories and ignition working, so that battery doesn't drain.
I still have my Schumacher 1A manual wall wart. It has brought back batteries that my automatic chargers refused to charge - or at least get a battery up to at least 9V where the automatics would start working. I checked it with my automatic (has a crude voltmeter when it's not charging) and it was reading around a 16V open circuit voltage.
