Originally Posted By: STG
Originally Posted By: wayniac
I have the 6.0 with the HEUI system.... Ford rec's the 15-40 ONLY, according to the dealer, and owners manual, however there is a temp sens chart that shows it being OK at extremely low temps.
WRONG.
Read this entire page and count the total number of Motorcraft diesel oils spec'd for the 6.0.
I suspect what he was trying to say is that the "recommended" vis from his dealer was to use only 15w-40. IOW, the "dealer says that Ford says ..." which is, obviously, open to a lot of mis-information. Ford clearly approves multiple product grades for the 6.0L.
Like I said, some portions of the diesel industry are still locked in the 15w-40 mentality. Others are beginning to open their eyes. I have yet to see any UOA example where a lighter grade resulted in high wear and detrimental abuse. Surely, one must make certain to use a lube that is HDEO rated when choosing a lighter grade; typical PCMO 10w-30 won't cut it in a diesel. But the market specific products perform well.
In central TX, I don't know that the lighter grade will really make a lot of different in cold starts over a 15w-40; there may not be much of an advantage in that area. But for us folks in the colder parts of North America, the 10w-30 really helps quiet the romp of HEUI in both the older 7.3L and 6.0L PSDs. The avearge low in Houston is only 45 deg F in Jan; that's not cold at all, and 15w-40 should start up just fine. There really isn't as much temperature variation in that area, contrasted to the mid-west.
Example:
Houston average low is 45, and average high is 95; a 50 degree spread
Indy average low is 18, high is 85; a 67 degree spread. And we do get into the high 90's often as well as down below zero a few times each year.
If I were the OP, I would choose whatever product I could find on sale, because his environmental concerns are minimal. 10w-30 or 15w-40 would work equally well in his area, most likely.
Coming full circle all the way back to his original question, the pressure difference between the 40 and 30 grade won't make any real differnce in his area. He might try it and really like it; good for him. He may decide he does not like it; that's ok too. Fundementally, it won't hurt his ride to use the lighter grade, and he may get a slight bit better starting. The ECM will direct the IPR to compensate for a range far greater than this little nuance will affect the system anyway.
