- Joined
- Sep 2, 2016
- Messages
- 255
The variable valve timing sensor (or what BMW calls the eccentric shaft sensor) on some BMW engines are prone to failure due to oil ingress in the sensor. The oil eventually fouls the connector, and there is even a TSB from BMW about the oil migrating through the wiring and damaging the ECU: https://static.nhtsa.gov/odi/tsbs/2016/MC-10151300-9999.pdf
Replacing this sensor requires removal of the valve cover, which is a bear of a job and can take up to 6 hours. Dorman sells a revised sensor under their "OE Fix" line, where they claim to address the original issue with ultrasonic welds, but the reviews are mixed: https://www.dormanproducts.com/p-77342-917-030.aspx
My stupid question is can't we just seal the sensor up with some kind of sealant to prevent oil from contaminating the internals?
Part number is 11377524879 if you are interested: https://www.fcpeuro.com/products/bmw-eccentric-shaft-sensor-valvetronic-11377524879
