Hello,
I've long been a lurker here at BITOG, trying to wrap my head around the earth's lubricant...and figure out which one to put in my car's engine.
Motor Spec:
2.4L KA24DE-T
DOHC Shim on bucket
Borg Warner S256 turbo (15-25psi)
Wiseco 9:1 forged pistons .0035" clearance
Wiseco rings with .018", .022" ring gap
ACL coated bearings
400-500hp
Oil Cooler w/180 degree thermostat bypass
I tuned it myself for stoich cruise and 11.5:1 AFR on full throttle. Still gets 25mpg if I'm nice.
I usually just putt around in this car since I'd be in jail or dead if I actually drove it hard on the street. However, I do go to street legal drags and would like to do a couple of track sessions next year.
I'm looking for an oil that will be suitable for the oil-lubricated and oil-cooled journal bearing Borg Warner turbo. The motor also has the shim on bucket cams, which I recall reading requires a bit more of the phos and zinc content (correct me if I'm wrong).
Please advise. Thinking about the Mobil 1 15w-50, and Amsoil 10w-40 for spring and 20w-50 for summer and racing.
Is there a specific oil that is great with fuel dilution, heat, journal bearing turbos and shim on bucket cams?
Thanks,
Nate
Motor Spec:
2.4L KA24DE-T
DOHC Shim on bucket
ACL coated bearings
400-500hp
Thanks,
Nate
