Just returned from a 7,114 mile cross country trip in our 95 Chevy Sportvan, running the same batch of QS Defy 10w30. Oil hit long pull 13,600 mountains, and also 4 hours of stop and go in both Los Angeles and Chicago. Oil isn't overly dark, and I will be sending it in just for reference. It also sealed up a leaky Rear main along the way!
Now for my observation. After about 3-3500 miles, the engine would drain back oil pressure after each shut off. As most engines have a slight knock after a fresh oil change for first start, this was doing it after every restart. Oil pressure when running however was about 45psi, and never fluctuated much. I had a small bucket, and changed just the filter to see if the anti drain back went weak, but....it did not change anything. Is it possible the oil had too much dilution?
