Originally Posted By: Kyonic
I have narrowed it down to Mobil 1 5w-30 and Pennzoil Platinum 5w-30. Not sure which just want to keep the warranty going.
In that case the only choice is the Pennzoil Platinum 5w30, as it meets the requirements for hyundais warranty. I think the cert was ACEA A5 that Mobil 1 didnt meet (maybe the Extended performance did, but i dont think so).
Factory fill is shell helix 5w30 semi syn.
As a side note, I kind of mentioned it above but... if you are changing the oil yourself through typical means such as pulling the car on ramps, be sure to use a fluid extractor to get the most out possible. the drain plug is on the front of the pan, so the ramps tilt the pan back. I get about 3/4s of a quart out after draining from the pan.
