Originally Posted By: turtlevette
It's semantics whether you call the spring a relief spring or pressure regulating spring.
Sure, but that wasn't your initial position:
It's not a relief. It's a pressure regulator which is partially open at anything above fast idle.
So at least we've got that out of the way
The crux of the disagreement is whether the pump bypasses most of the time (my assertion) or almost never (shannow group).
If you have 40psi hot idle at 600 rpm what is the approx pressure at 1200? 80?
then what's the pressure at 2400? 160?
what's the pressure at 4800?
and on to redline. It doesn't take many rpm to get into bypass.
Have you never owned an engine with an oil pressure gauge? I've posted numerous times on this that observed pressure does not double with RPM due to the reasons Shannow has now touched on, which are the other components in the engine, particularly the bearings, consuming more oil downstream.
My old SBF was ~32PSI hot idle (850RPM), ~45psi at 3,500 and onto the relief (65psi) by around 5,000-5,500 IIRC.
We can argue about where it occurs
Easy enough to determine on any vehicle with an oil pressure gauge really.
and that a thinner oil will bypass at a higher rpm.
I don't think there's anything to argue about there. If observed oil pressure is lower with a thinner oil (which, in my experience, it is, but only by a few PSI), then it will take more RPM to create enough pressure to open the relief than it will with a heavier lubricant.
Quote:
Why do you suppose there is so much emphasis on developing variable displacement pumps vs the constant displacement most vehicles have now. Efficiency. An oil pump bypassing most of the time wastes energy.
Approached from another angle: Oil that is cooler, and subsequently thicker, will lead to unnecessarily high oil pressure, as the engine doesn't need (can't consume) the volume of oil being supplied. Taking an SBC for example, not on the relief, rolling down the road at 60Mph and 2,500RPM, sump temps are lowered by airflow over the pan so operating viscosity is up. Oil pressure is 40psi. Does the engine need 40psi of oil pressure to be properly lubricated in that state or is the engine just wasting power? Note the relief is still closed in this scenario.
Variable displacement pumps (which there is a great article on from the ASME
here )
Originally Posted By: ASME
Fixed-displacement oil pumps currently circulate oil in most automobiles. Designers typically oversize the pumps to handle the harshest engine operating conditions. Most of the time, they consume more power and deliver significantly higher oil pressure than needed. They contain pressure-relief valves as a crude, cost-effective, and reliable way to avoid excessively high oil pressures. But these designs are inefficient, losing significant amounts of energy at high oil flows typical in internal-combustion engines.
as noted, work to "solve" that problem, by providing the volume and pressure the engine needs at a given point rather than the scenario depicted above with the conventional pump.
Quote:
If bypass events were rare why bother to develop a more efficient pump?
See above.
Think about it.
We have been and are.
And remember the pressure monitoring point on most engines is after the filter where there is a bit of pressure drop. You may see 40psi on the gauge when there is really 50psi at the pump.
Let's get this right.
Yes, the filter can provide some pressure drop. That's going to depend on the viscosity of the lubricant of course and the volume moving through the media. Hot oil is going to provide much less of a pressure drop than cold oil and the same goes with higher volume and of course a combination of the two. Note that the total pressure drop is controlled by the bypass in the filter itself, as it will only allow a set amount of differential pressure before it starts bypassing the media.
Gary Allen on here quite some time ago (RIP) had a rather cool setup on his jeep 4.0L where he put oil pressure gauges before and after the filter to monitor bypass events FWIW.
Yes, let's get this right. Which means not attacking anyone's credentials because you don't agree with them and instead sticking to civil discussion.
