Note: per previous thread, this vehicle is for my "sister" not myself
Actually picked it up the other day with her, haven't had time to take pictures during the day till now, after I cleaned it up and stuff. So it's a 1998 Grand cherokee, bought for $1,500. It had a bad rough idle, changed out spark plugs and wires, distributor cap and rotor, and now idles perfectly.
Cleaned it up, there are a few small issues, the interior light bulbs are burnt out and the amp for the radio doesn't work. Other than that, it's in pretty good condition considering. The only real "issue" is that when cold the 42RE tends to slip from 1st to 2nd gear under moderate throttle. Under WOT or light throttle it's fine, but moderate throttle slips during the shift, and generally only when cold. From what I've seen/read, this isn't an alarming problem and will probably last for a long time with it. If I need to though I can always pull one out of a junkyard car for it for a song.
Work I've done to it so far
-Plugs (replaced with Champion Coppers)
-Plug Wires (xact brand from Advance)
-Distributor cap and rotor (NAPA Brand)
-Lubegard red in ATF (Last owner used B&M Trickshift, will change with ATF+4 eventually)
-air filter (Puro classic)
-Oil change (QSGB 5W-30 w/Purolator Classic
-Added some Maxlife PSF to Power steering resovoir
-Had new pads put in before we got it.
Work to do- replace interior bulbs, tensioner pulley squeals, radio amp.
It runs beautifully, certainly feels like a 1998 Jeep though, reminds me a lot of our wrangler in the way it drives.
