Originally Posted By: MKZman
Originally Posted By: bubbatime
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3213014/1
Check out my craigslist score post from several months ago. Front drivers use low quality transmissions and plastic wheels - avoid them if possible. Look for an aluminum deck toro or a snapper ninja/high vac. They are 30 year mowers with regular maintenance.
If it has a Kohler engine, avoid it like the plague. I would also avoid the regular Toro Recyclers (steel deck). I've worked on several last year and they were just junk. The aluminum deck toro mowers are 10x the quality.
The older craftsman mowers were ok, the newer ones last 5 years. The quality has dropped so far it's embarrassing .
I have two mowers with Kohlers Scotts circa 2001, Husquanva 2012) and no issues. I also have two regular Toro's. The Toro are still better than others with thinner cheaper decks but the run fine. I do not do anything except change oil and filter each season.
I was referring to the Kohler push mower engines. They ALL are made in China, and they ALL have problems, some sooner, some later. The carb's are low quality junk. The auto choke frequently needs work/replaced. They are also low on power and the RPM is way too low from the factory. One would be much better off with a Briggs or Honda.
The larger Kohler rider mower engines are OK.
