They will spin in reverse, but with high turbulence. The worst problem is at the equator where it starts spinning both ways, sort of like the churning of a washing machine. Many engines have blown up on the equator. Hence the donkeys to pull trucks through (they weren't just to get the trucks through the mud).quote:
Originally posted by kanling:
You have to be careful with those spiral flow oil filters. If you accidentally drive into the southern hemisphere you have to change it to one that spins the opposite way or else the spin imbalance will cause the filter to explode!
I think Baldwin makes, one of the best overall, oil filters. Seems like it both flowed and filtered above average, and you have a canister about as tough as it gets. All for a good bit less than a Mobil/K&N.quote:
Originally posted by SKUNKY:
I was at NAPA today and saw these filters..do you think they will flow more oil?? How about filtration numbers?? At 3.50 / filter it's cheaper then the Baldwins I use...
