Mystik 15/50 SM/CJ4 - 2014 Road King - 2,809 Miles
North Carolina Coast
I guess I am happy with this oil.
Did a mid run sample test at 1,334 miles and 7 weeks later final result of the same oil at 2,809 miles. Engine is quiet and has stayed that way throughout the 2,809 miles. I have now changed it at time of sample to a fresh refill of the Mystik 15/50.
UOA removed by OP request
Here is the link, I, still to this day can not post the image reliably *L*
Then the time to edit runs out and can no longer go back and correct it.
Ok, finally, lets try this again ..
Not sure why I always have an issue posting an image on this site ... but here is the link, that works.
JUST A NOTE TO THE ABOVE UOA, BLACKSTONE HAS THE OIL INCORRECTLY MARKED ON THE REPORT AS A 15/40.
THE OIL TESTED IS MYSTIK JT8 SEMI SYN 15W50.
Originally Posted By: FastGame
Hmmm the oil got better as the miles increased ???
Yeah, why is that? 10% margin of error in these tests or some oil that burns off leaves a higher percentage of elements?
This oil was run in HOT weather, it is NEVER below daytime temps of 90 degrees where I live, more like high 90s to low 100s is the norm.
Alot of interstate but also a fair amount of local and some heavy traffic.
I did notice vis held up, though it is more like a heavy 40, that's ok by me.
