Hello all, I have a 2005 Ram SRT-10 with the Gen 3 viper engine. 47k miles.
Current mods include;
CAI
Ported Throttle Body
SCT Tuning
Ported intake manifold
Port matching for the Throttlebody/manifold/heads
Longtube headers
A fairly aggressive cam and the subsequent head upgrades
165F thermostat
SPEC twin disk clutch
The owners manual specifies a maximum OCI of 3k with Mobil 1 0w-40. My truck makes about 100HP (a little over 600) over stock and does spend most of its life on a track in 100F+ temps. Oil temps even with dual coolers can peg the gauge at 300F+.
I found that mobil 1 15w-50 quiets the engine ticking noises down a lot.
So far I have run;
Mobil 1 15w-50 (last racing fill)
Castrol Edge 5w-50 (sounded like the M1 0w-40 after a few hundred miles.)
Royal Purple 15w-40 (it seemed to really like this stuff)
Mobil 1 Turbo Diesel Truck 5w-40 (Also slightly quieter than the 0w-40)
Valvoline VR1 20w-50 and 10w-30 at varying mixtures. (Seemed to blacken a lot less than other oils)
Pennzoil platinum 10w-30 (Made TONS of noise!!!)
Next up I'm not sure what I'm gonna run, but I have some RedLine 10w-60 that I picked up on an ebay auction for $5 a quart, and I'm kinda itching to see what it would do!
When I got the truck it was severely neglected. I bought it 1200 miles from home, and changed the oil 4 times within that drive because it would turn sludge black in 200 miles. When I got it home I ran a few 1k OCI's with a full can of Seafoam and then MMO in the crankcase. That seriously helped. It seems to be all clean now! I can now run to about 2700 miles before the oil is quite dark. I am fairly comfortable with doing 3k OCI's as its cheap insurance vs a 15 grand engine. It takes 10 quarts per change, and I use an amsoil eao26 oversized 2qt filter that is used for 2-3 OCI's depending how much [censored] has seemed to dislodge.
So, I know it's been a long read, but is there any oil in that list that I have made a mistake by using? The truck seems to run much better the thicker the oil including power. I attribute this to the extremely high bleed lifters. Anything you guys would do differently? Am I on the right track with thick, high zinc oils?
One more thing, other fluids include Amsoil 75w-140 gear lube, Amsoil ATF trans fluid, ATE Super Blue Dot 4 brake and clutch fluid, and G-05 Premix coolant with watter wetter.
Oh, and it will pull to 160mph in 5th gear...
CAI
SCT Tuning
Longtube headers
165F thermostat
So far I have run;
