It came in kit form.
Guy on craigslist had some steel tubing for sale, so I went to get some, and I asked him if he had any sheet metal. He says, "Well, I've got this big 'ol plate over here that used to be under a fireplace. Kinda heavy."
No kidding. He had a 43 1/4" square piece of 1/4" plate. Probably about 200 lbs. I asked him how much, and he said $5.00. I also bought about 20' of 3/4" square tubing, about 20' of 1/2" square tubing, and some really big rectangular tubing that I haven't measured. $25.00 out the door.
I wanted to make a welding table, so I cut the plate 24 1/2" wide. I'll use the other piece for a "backsplash". I don't have a plasma cutter, so I cut it with a carborundum blade on a circular saw, which took quite a while, and wasn't all that pretty.
I've begun welding the 1/2" tubing along the front and back edges. Here's one of my better welds.
I realize it's ugly, but considering that I've been arc welding for about a month, I hope you'll cut me some slack. I used some ancient 6010 rod that I got for free. 75 amps, IIRC. In any case, I should soon have a very heavy table. I'll use the 3/4" tubing for the legs, and weld 1/2" nuts to the bottom of them so I can level it.
