Long Run, unless your truck has a limited slip rear end, the NS is what you use. Kind of confusing, the NS is for rear ends with OUT limited slip. The regular 75-90 has a friction modifier in it. I would also go with the MTL for the trans, it will shift a lot smoother and quicker than the heavier stuff. (unless Nissan says to use it) Jim
