Originally Posted By: BuickGN
Originally Posted By: Max_Wander
Originally Posted By: MNgopher
Dropping out of OD also works for engine braking on those long downhill grades.
And yes, your tach starts to spend a lot of time at higher numbers than you are used to as a "flatlander".
Sometimes I'll force the Camry's ATX into first gear to slow down. The thing with it is that it won't downshift to 1st unless the speed is below 50KM/H, which pushes the RPMs to a measly 4500. By putting the gear selector in L (1st), hydraulically, routes pressure to the first gear clutch, but the TCM keeps the 2nd solenoid open until the speed drops to 50km/h. Forget that, so I switch the ignition off with the lever in L at speeds upwards of 65km/h, that way with no power, the computer can't prevent the downshift and I can use all the engine braking from 5500 down
It might sound abusive, but it's not really, as long as it doesnt downshift into redline. People must be wondering, seeing the DRLs turn off and then on again
I took this as a joke at first. Now I'm not sure. What are you trying to accomplish by downshifting at 5,500rpm? Save the brakes but kill the engine? You do realize the effective redline is lower when the engine is not under load, right? It's easier to hurt things from excessive rpm without a load on the engine.
Shut the engine off, no power steering no power brakes, over heat the AT. Doesn't sound like a good idea. I'll never do it.
I'll anticipate ahead of time if possible what gear I need, with a MT its pretty easy, I'll take a decline in 2nd or 3rd gear, and tap the brakes when needed. If I'm going up and down hills with an AT, I'll use either drive or second, and if speed is building up too much use the brakes. I've been all over the US driving and haven't ruined a clutch, AT or smelled brake linings burning yet. Anticipate ahead of time what gear you think you'll need, upshifting because you're using too low a gear is very easy. Brakes are cheap, transmissions and clutches aren't.
