This is what I saw the last time I opened the manual for an insight of oil choice. I only caught "229.1" and wide oil range selection according to temperature.
But then it says "except for Clear Tec" (basically 1,3 and 1,1L engines equipped with stop and start and 0W20 oil from factory), and "except turbo engines"...
Actually you have to go several pages further to find the correct graph for turbo engine (4G15T which is different from NA 1,5L engine), and then
Back in the eighties! Yes it is a 2010 car, and the manual is the one that came with it. I guess since the engine was created in the eighties and not that much modified (not talking about injection or ignition but strictly mechanically) since (major change is it went from timing chain to timing belt in 2010).
According to the manual, API SG and 20W40 grade sounds good. 10W30 like Jetronic said is good too (except it is the one grade I can't find here). 5W30 is tolerated in cold climates to ease starting at low temperatures, so I guess 300V should be ok too! I could even use 5W30 instead of xW40 grade.
I still have to imagine 10000Km (that's what the manual says) with mineral 15W40 and a 3L sump.
At the moment it runs fine and smooth with 300V 0W40, no tick or rattle or whatever (but there was none before)
HT but M1 0W40 is slightly noisier in my Barchetta (than previous 5W40), not cold nor warm but in between, slightly more variator noise. No lifters tick when cold, no variator noise when hot.
