I have an issue with brake fluid degrading rapidly.
1982 Kawasaki KZ550.
This bike has a single front caliper, floating style. I have replaced the master cylinder with a new unit, and replaced the rubber brake line with a SS braided line.
I flush the brake fluid at least once a year. The brake fluid has been flushed 4 or 5 times since I have owned the bike (the brake fluid was black when I bought it.) The only original part of the brake system is the caliper. I have no performance issues with the brake. The brake lever is firm (not as firm as a new bike, but I assume brake systems have improved in 30 years) and I can lock the front wheel at will. I have no issues with brake fade, but I don't ride this bike very hard. It rarely sees more than 5,000 RPM.
The brake fluid turns dark much faster than the fluid in any car I have ever owned. Correct me if I am wrong, but dark fluid is because of contamination. I have always used auto parts store DOT3. Is my cheap brake fluid the problem or is it time to find a rebuild kit for the caliper?
