Mobile 1 10W/30, 4450 miles on the oil. 13 months since previous change.
2000 Nissan Frontier 3.3L V6 with 52,700 miles on vehicle
Daily driver, Less than a 10 mile commute plus errands, occasional longer trips on the weekends.
This last winter it was parked outside, not plugged in, and started readily every morning in all Montana weather including -25F (-32C).
Kinda looks like I need to get a block heater, and switch to an oil that can better handle cold starts. 0w-20, and something other than Mobile 1 maybe?
Blackstone comments:
Quote:
Wear metals were quite high in this sample from your Nissan. Universal averages show typical wear levels for this type of engine after about 4,400 miles on the oil. There's no obvious explanation for the wear, so it's hard to say what's causing it. Aluminum is from the pistons and iron is from steel parts. Copper and lead generally show bearing. Copper can also be from any other brass/bronze part. No coolant was found and the trace of fuel isn't an issue. If the engine saw any hard use or recent work, that might explain it.
Resample in around 3,000 miles.
Code:
MI/HR on Oil 4,457
MI/HR on Unit 52,721
Sample Date 06/25/11
Universal
Averages
ALUMINUM 20 4
CHROMIUM 2 1
IRON 129 14
COPPER 14 4
LEAD 40 10
TIN 0 0
MOLYBDENUM 82 80
NICKEL 1 0
MANGANESE 3 1
SILVER 0 0
TITANIUM 0 0
POTASSIUM 7 5
BORON 103 44
SILICON 16 11
SODIUM 19 38
CALCIUM 3159 2215
MAGNESIUM 23 119
PHOSPHORUS 892 682
ZINC 1056 829
BARIUM 0 0
PROPERTIES Should Be
SUS Viscosity @ 210°F 60.5 58-68
cSt Viscosity @ 100°C 10.35 9.7-12.7
Flashpoint in °F 360 >365
Fuel % TR
Antifreeze % 0.0 0.0
Water % 0.0 0.0
Insolubles % 0.4
Code:
MI/HR on Oil 4,457
Universal
Averages
ALUMINUM 20 4
CHROMIUM 2 1
IRON 129 14
COPPER 14 4
LEAD 40 10
TIN 0 0
MOLYBDENUM 82 80
NICKEL 1 0
MANGANESE 3 1
SILVER 0 0
TITANIUM 0 0
POTASSIUM 7 5
BORON 103 44
SILICON 16 11
SODIUM 19 38
CALCIUM 3159 2215
MAGNESIUM 23 119
PHOSPHORUS 892 682
ZINC 1056 829
BARIUM 0 0
Fuel % TR
Water % 0.0 0.0
Insolubles % 0.4
