Here is my 2nd UOA from my 2012 Nissan Versa with the HR16DE engine. Lots of extremely short trips each day and plenty of cold starts. Refilled with the same lube even though it is spec'd for 5W-30. It was on sale for $3/qt. Maybe because it had water it? No seriously, the water is likely from the Arctic conditions and short trips and therefore ALS was unable measure viscosity.
ALS Diagnosis: All engine wear rates normal. Light concentration of
water present. Silicon level (dirt/sealant material)
satisfactory. Unable to obtain accurate viscosity result
at 100C due to presence of water in sample.
Action: Check for source of water entry. Resample next
recommended service interval to further monitor.
Code:
OIL Mobil 1 EP Kendall
5w20 5w30
Synthetic Semi-Synthetic
MILES IN USE 4,176 4,083
MILES 44,180 37,087
SAMPLE TAKEN 10/16/2015 10/18/2014
Metals (ppm)
IRON 18 6
CHROMIUM
LEAD
COPPER 8 15
TIN
ALUMINUM 4 7
NICKEL
SILVER
TITANIUM 5 85
VANADIUM
Contaminants (ppm)
SILICON 23 13
SODIUM 8 6
POTASSIUM
Additives (ppm)
MAGNESIUM 621 22
CALCIUM 1408 2238
BARIUM
PHOSPHORUS 779 703
ZINC 870 814
MOLYBDENUM 86 93
BORON 102 156
Contaminants
WATER .17
Coolant No No
Physical Tests
Visc (cSt 100C) N/A 9.1
TBN (mgKOH/g) 4.0 5.1
Code:
5w20 5w30
MILES 44,180 37,087
Metals (ppm)
IRON 18 6
CHROMIUM
LEAD
COPPER 8 15
TIN
ALUMINUM 4 7
NICKEL
SILVER
TITANIUM 5 85
VANADIUM
Contaminants (ppm)
SILICON 23 13
SODIUM 8 6
POTASSIUM
Additives (ppm)
MAGNESIUM 621 22
CALCIUM 1408 2238
BARIUM
PHOSPHORUS 779 703
ZINC 870 814
MOLYBDENUM 86 93
BORON 102 156
Contaminants
WATER .17
Coolant No No
Physical Tests
