Report date 01/19/06
Oil Type: Mobil 1 2/3 mix of SM 5W20 and 1/3 mix M1 SM 0W40 on 01/10/06 oil sample
Oil Type: Mobil 1 50/50 mix SL 0W20 and M1 SM 0W40 on 10/01/05 oil sample
Mileage on oil: 5100 miles
Time on oil:slightly over 2 months
Ford: manufactured by Kia
Model: Aspire
Year of car: 1997
Year of engine: 1993
Engine: 1.6 dohc turbocharged B6T Mazda design from a 1993 XR2 Mercury Capri .
Mileage on engine: 147,100, no rebuild.
Oil filter: Larger Purolator Pure One PL14610 from a Mazda V6 engine.
Air filter: K&N cone filter with a K&N oiled foam pre filter installed over the cone filter.
Make up oil 1 qt.
Cam seals,front and rear main seals,silicone oil pan gasket,head gasket,valve cover gasket replaced 15,100 miles prior to the latest analysis.
Fuel: Premium Unleaded.
Transmission: 5 speed manual
Miles on oil 5100 / 5300
Miles on unit 147,100 / 142,000
Sample date 01/10/06 / 10/01/05
Unit averages/Unit averages/ Universal averages
Aluminum: 2 / 2 / 3
Chromium: 0 / 1 / 1
Iron: 8 / 8 / 9
Copper: 1 / 1 / 3
Lead: 1 / 1 / 1
Tin: 0 / 0 / 0
Molybdenum: 73 / 72 / 49
Nickel: 0 / 0 / 0
Manganese: 0 / 0 / 0
Silver: 0 / 0 / 0
Titanium: 0 / 0 / 0
Potassium: 3 / 0 / 1
Boron: 95 / 86 / 44
Silicon: 15 / 24 / 7
Sodium: 5 / 5 / 3
Calcium: 3084 / 2483 / 2342
Magnesium: 13 / 13 / 53
Phosphorous: 777 / 698 / 786
Zinc: 966 /846 / 946
Barium: 0 / 0 / 0
SUS Visc. at 210F: 58.8 / 58.9
Flashpoint: 370 / 375
Fuel: < 0.5
Antifreeze: 0 / 0
Water: 0 / 0
Insolubles: 0.4 / 0.4
Blackstone comments.
If the K&N pre-filter and/or cone filter has any silicone content to it, that might be the reason for the 15 ppm of silicone. Otherwise, it could be excess dirt getting past the air filter, so you may want to check that out. All of your engines wear metals read below the universal averages ,which are based on a 3500-mile oil run, for this type of engine. The TBN registered at 6.1 ,loads of active additive remaining in the oil, - 1.0 is low. No fuel, water or anti-freeze was found and the viscosity measured in the upper SAE 20W range @210F for your oil mixture.
I am pleased that the silicon levels dropped with the addition of the oiled foam K&N installed over the K&N cone filter. The air must be getting filtered a little better. Chromium went to 0 so that sounds like less ring wear from dirt. Silicone may be still leeching out of the RTV pan gasket and I have noticed a few small chunks of RTV that have come out when draining the oil.
The oil was dark brown in color when changed. I will continue to change the oil and filter at 5000 mile intervals even with the high TBN still there.
This car is driven in a spirited manner on a 70 mile a day commute with a mix of interstate and town driving delivering 30 to 34 mpg. There were 2 short 5200 rpm top gear 120 mph+ runs on this oil change. The thin oil blend is protecting the engine well according to the UOAs and the throttle response and turbo spool is very crisp. Based on these results I feel comfortable running a thinner oil in an older engine and will use a similar blend in our other vehicles
Model: Aspire
Year of car: 1997
Make up oil 1 qt.
Aluminum: 2 / 2 / 3
Chromium: 0 / 1 / 1
Iron: 8 / 8 / 9
Copper: 1 / 1 / 3
Lead: 1 / 1 / 1
Tin: 0 / 0 / 0
Nickel: 0 / 0 / 0
Silver: 0 / 0 / 0
Titanium: 0 / 0 / 0
Boron: 95 / 86 / 44
Sodium: 5 / 5 / 3
Barium: 0 / 0 / 0
Fuel: < 0.5
Antifreeze: 0 / 0
Water: 0 / 0
