JHZR2
Staff member
Hi,
Here is our first analysis of API SM M1 5w-30 oil. This is from my mother's 1997 plymouth breeze, which now has 83044 miles. This car has the 2.0L 4-cyl engine, and a 4-sp AT.
I am very pleased with the results, especially considering that the interval was much longer than before. The car runs great, has been getting great gas mileage, and there have been no problems. FP has been used on and off, LC has been used at the necessary dosages for the most part. A purolator pureone filter was used, and there was no top off required.
The one difference in this OCI is that whereas my mother usually uses this car for a 5 block drive 6x per day, a lot of the driving done in this car for this past OCI was my father taking it on 40 mile drives 2x per day, and then when my parents would go away. about 200 miles every other weekend. So there was a LOT of highway driving on this one compared to usual, and my father drives VERY gently, and was trying to maximize fuel econoimy at the same time...
code:
Sample Date 12/1/2005 1/9/2005 4/10/2004 5/12/2003
Unit Age 83044m 74568m 69259m 64250
Time on Fluid 8476m 5309m 5000m 4500m
Time on Filter 8476m 5309m 5000m 4500m
Fluid Maint. Changed Changed Changed Changed
Filter Maint. Changed Changed Changed Changed
Fluid M1 5w-30 M1 5w-30 M1 5w-30 M1 0w-30
Iron (Fe) 8.1 27 16 21
Chromium (Cr) 0.2 0.7 0.5 0.8
Nickel (Ni) 0.9 0.6 1.3 1.1
Titanium (Ti) 0 0.1 0 0.2
Silver (Ag) 0 0 0 0
Aluminum (Al) 3.9 6.7 6.7 8.2
Lead (Pb) 0.7 0.2 1.2 0.2
Copper (Cu) 3.5 6.3 1.7 2.9
Tin (Sn) 0 0 0.3 0
Silicon (Si) 7.9 93 23 11
Sodium (Na) 3.8 5.8 3.9 5.2
Potassium (K) 0 0 0 0
Boron (B) 53 133 176 142
Barium (Ba) 0 0 0 0
Molybdenum (Mo)129 77 79 67
Magnesium (Mg) 8.2 23 22 20
Calcium (Ca) 1469 2633 2889 2510
Phosphorus (P) 609 801 848 820
Zinc (Zn) 629 929 952 928
Sulfur (S) 3960 2249 2242 2373
Cadmium (Cd) 0 0 0 0
Manganese (Mn) 0.1 0.4 1.2 0.5
Vanadium (V) 0 0 0 0
Soot(%) 0 0 0 0
Oxidation(PA) 70
Nitratrion(PA) 65
Sulfation(PA) 63 90
ZDDP -0.08 -0.1 0 0
Kv@100°C 10.4 10.9 11 10.66
White Metal NONE NONE NONE NONE
Babbitt NONE NONE NONE NONE
Precipitate NONE NONE NONE NONE
Silt NONE NONE NONE NONE
Debris NONE NONE NONE NONE
Dirt NONE NONE NONE NONE
Appearance NORML NORML NORML NORML
Odor NORML NORML NORML NORML
H2O(Emul) NEG NEG NEG NEG
H2O(Free) NEG NEG NEG NEG
