Originally Posted By: SR5
So that leaves foaming as the property that stands out to me.
Believe it or not, both B3 and CG-4 use the same ASTM D892 standard
Incorrect. I mentioned this earlier in the thread...
"In the HEUI fuel system, the engine oil from the oil sump not only lubricates the engine, it also supplies a high-pressure oil system that takes oil from the main gallery and pressurizes it up to 20.7 MPa in a plunger pump. This oil is used to operate unit injectors that, when used in combination with intensifiers, increase the fuel injection pressure up to 145 MPa, independent of engine speed. The electronic controls permit varied injection timing and duration to provide optimum fuel economy and emissions. This system may, however, circulate all the oil in the sump in approximately 8 s; as a consequence, aeration of the oil can occur with some engine oils. International determined that 8% oil aeration was the limit beyond which engine operation and performance would be impaired in actual service.
Prior to 1994, the ability of an engine lubricant to resist aeration was measured by Test Method D892. During the development of the API CG-4 category in 1994, however, it was found that this bench test did not correlate with aeration in the International T 444E engine. The EOAT was developed, therefore, to provide a better measurement of the ability of a lubricant to resist aeration during engine operation.
This test method was designed to evaluate an engine oil's resistance to aeration in automotive diesel engine service. It is commonly referred to as the Engine Oil Aeration Test (EOAT). The test is conducted using a specified 7.3L, direct-injection, turbocharged diesel engine on a dynamometer test stand. This test method was developed as a replacement for Test Method D892 after it was determined that this bench test did not correlate with oil aeration in actual service. The EOAT was first included in API Service Category CG-4 in 1995."
In case anyone has forgot by this point, OP's engine is a 7.3L Power Stroke/T444E.
