Report Date: 1/5/2012
Make/Model: Suzuki 1.8L 16 Valve
Oil Type & Grade: Mobil 1 High Mileage 10W/30
Fuel Type: Gasoline (Unleaded)
Oil use interval: 6,500 Miles
Your Suzuki Esteem scores very well in this first report, with most metals reading at or below average levels even though you're running a fairly long oil change. Our universal averages show typical wear for this type of engine after about 3,200 miles of oil use, and since you're getting comparable wear after more than twice as long on the oil, it looks like your engine is running smoothly and has no mechanical issues developing. The oil was free from contaminants and the TBN was good at 3.9, indicating plenty of active additive remaining (1.0 is low). Nice one!
Code:
Miles on Oil: 6,500
Miles on Unit: 138,000
Sample Date: 12/22/11
Make up oil: 0
ALUMINUM 3
CHROMIUM 0
IRON 3
COPPER 12
LEAD 0
TIN 0
MOLYBDENUM 72
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 4
BORON 46
SILICON 9
SODIUM 0
CALCIUM 1111
MAGNESIUM 637
PHOSPHOR 792
ZINC 828
BARIUM 0
Values Should Be
SUS Viscosity @ 210°F 63.0 59-68
cSt Viscosity @ 100°C 11.05 9.9-12.7
Flashpoint in °F 405 >375
Fuel %
Antifreeze % 0 0
Water % 0
Insolubles % .3
TBN 3.9
TAN
ISO Code
Code:
Miles on Oil: 6,500
Make up oil: 0
ALUMINUM 3
CHROMIUM 0
IRON 3
COPPER 12
LEAD 0
TIN 0
MOLYBDENUM 72
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 4
BORON 46
SILICON 9
SODIUM 0
CALCIUM 1111
MAGNESIUM 637
PHOSPHOR 792
ZINC 828
BARIUM 0
Values Should Be
Fuel %
Antifreeze % 0 0
Water % 0
Insolubles % .3
TBN 3.9
TAN
ISO Code
