Mobil 1 0w-40 I think it was SM but can’t remember for sure. Toyota 90915-20004 oil filter from my filter hoard, Previous owner had put in a K&N air filter witch was promptly replaced with OEM paper upon discovery not long after purchase and also not long before the first analyzed OCI was started. No additives or fuel treatments this OCI, use mostly Chevron gas, always 93 octane.
This OCI was 5,491 miles over 3 months. Total consumption some burned some leaked externally is somewhere around 2 quarts with only one made up @ 4,371 miles into OCI. Sump capacity is just shy of 8 quarts. Toyota fuel injected dual overhead cam 4.5L inline 6 with an overbuilt oil system.
Miles were mainly freeway commute, -0- short trips, it is 7 miles one way just to the closest gas station/food. And 35 miles to work. Spend a lot of time with the cruise set at 75-85, it may see higher average RPM than most cruisers.
Wal-Mart SuperTech 10w-40 and 16oz of AutoRx went in this oil change. Plan on 2 cycles so I probably will not have another report until around the New Year so I am glad this one had no major surprises.
Past OCI’s:
6,362 Mobil 1 10w-30/15w-50 6 to 2 mix for winter.
3,948 Mobil 1 15w-50 last fall.
5,200 Delvac 1 5w-40 last summer.
Lead in this OCI is still above the average but trending down. Lead per 1,000 miles on the 4 different OCI’s:
0.91
1.10
1.01
1.73
universal average is 0.62 / 1k miles
Glad to see copper and tin stay low after both spiked in the first OCI.
Iron went up a bit and is for the first time above average, hopefully temporary
, maybe 0w-40 is not a good Georgia summer oil. Maybe it is nothing.
Molly calcium and Boron are slightly higher now than the earlier, are the anti wear additives higher in 0w-40? Or is this Mobil’s new formulation?
Other users with this engine get very good results, they look more like a VOA than a UOA. Hopefully over time with good care I will get there.
I would like to try the new Mobil 1 EP 10w-40 but I have not seen it for sale yet. May go bach to 0w-40 this fall after the Arx cycles, and then something thicker next spring
Any comments/info/suggestions/wild theories welcomed
Thanks for reading
Raven
Past OCI’s:
0.91
1.10
1.01
1.73
Thanks for reading
Raven
