In theory yes. Why not just use either of them without mixing? If it were me I’d use the 10w30 and not look back.I have a weird oil question.
I have a power washer that needs an oil change of 5W-30 oil.
I am out of that weight oil.
However I do have 0W-30 and 10W-30
If I mix an equal amount of each do I create 5W-30 ???
(I have a pharmaceutical background)
10w30 would be fine
Boring replies. CheersWhy not just use either of them without mixing? If it were me I’d use the 10w30 and not look back.
Just my $0.02
Most of the 0w30s have Euro backgrounds and are thicker viscosity at operating temperature than the 5/10w30s. So my vote goes for using the 10w30, as long as it's not a diesel-only oil. If it is, then it's probably thicker at operating temp than the 0w30. I'd rather choose the 0w30 than a Rotella, Delvac or Delo-type diesel 10w30.I have a weird oil question.
Truth hurts maybe. No gain in running a mixture when either would work by themselves. Save the 0w30 for a vehicleBoring replies. Cheers
The answer to your question is yes, but only mix the same brand and family of engine oils to prevent possible chemical incompatibility.I have a weird oil question.
I had my last lawn mower for 5 years and never changed the oil. Just checked it every time. Gave it away free when I moved. As a kid, my dad would randomly dump old weed whacker gas/oil mix into the push mower to use it up in the spring before he put a new spark plug in. I think that mower was about 30 years old before the engine seized. Big yard and I used it for a few years that I made some money mowing a few neighbors yards in late elementary through high school. I recommend being nice to engines, but most small engines, at least the old ones, could take a lot of abuse. The mower I never changed the oil on was a $79 basic, side discharge push mower.It's a pressure washer. It really doesn't matter as long as it's full.
Other than probably being more common / available nowadays, I can't see why a power/pressure washer manufacturer cares about the "W" rating. If it's cold enough than 5W vs 10W factor in, you ain't gonna be using a water-based washer, at least not outside in ambient temperatures !A lot of small engines call for 10w 30. If your not pressure washing in -20 weather your 10w 30 will be fine
