here is the 6.6k pull of the D1ESP in my Mazda Miata MSM(factory Turbo). this oil is going to be pulled as soon as i get home and i think i have an extra gallon for sale.. the miata is typically a kitten with oil, in my FX the D1ESP thickened out of grade (see http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1983006#Post1983006) and here it is about to drop out the bottom. i didn't get a TBN because it didn't even have 7k on the oil, but will try tomorrow. comparing the Ca, Mg and such, this oil looks in taters, and the Pb is highly disturbing. i expected better....QUITE a bit better.
Code:
Oil Filter--------M1-110
OIL D1 ESP5w40 M1 0w40
MILES IN USE 6,625 5000
MILES 21.6k 8.2k
SAMPLE TAKEN
ALUMINUM 4 3
CHROMIUM 1 1
IRON 16 20
COPPER 5 5
LEAD 17 6
TIN 0 2
MOLYBDENUM 17 96
NICKEL 1 2
MANGANESE 1 1
SILVER 0 0
TITANIUM 0 0
POTASSIUM 2 5
BORON 37 102
SILICON 14 21
SODIUM 9 5
CALCIUM 1475 2843
MAGNESIUM 625 15
PHOSPHORUS 922 844
ZINC 1199 1023
BARIUM 0 0
SUS VIS 210ºF 66.6 65.4
cSt @ 212ºF 12.05 11.73
FLASHPOINT ºF 420 395
WATER 0 0
INSOLUBLES 0.3 0.3
TBN
blackstone's comments
Originally Posted By: Blackstone
For the most part this 1.8L has matured nicely since the last time we tested it, though we did note
lead was reading out of line. Last time we attributed this to wear in, but at this point your Miata is past that
process, so we suspect this metal may be from another common source. One possibility is a particle streak,
which is when a particle gets lodged in the babbit, spins around taking metal off, and then gets dislodged. If
that is the case it should improve next time. All other wear looked good and the oil was in good shape too.
Check back on lead next oil change.
Code:
MILES 21.6k 8.2k
SAMPLE TAKEN
ALUMINUM 4 3
CHROMIUM 1 1
IRON 16 20
COPPER 5 5
LEAD 17 6
TIN 0 2
MOLYBDENUM 17 96
NICKEL 1 2
MANGANESE 1 1
SILVER 0 0
TITANIUM 0 0
POTASSIUM 2 5
BORON 37 102
SILICON 14 21
SODIUM 9 5
CALCIUM 1475 2843
MAGNESIUM 625 15
PHOSPHORUS 922 844
ZINC 1199 1023
BARIUM 0 0
WATER 0 0
INSOLUBLES 0.3 0.3
TBN
