http://www.eng.auburn.edu/~jacksr7/SAE2002013355.pdf
Shell paper I linked to in another thread...it's talking of N.A. engines, but the premise is the same.
Quote:
The strategy for minimizing engine friction in a Formula 1 engine is fairly simple. If the engine has a lot of boundary friction, you would use a higher viscosity lubricant, with a friction modifier, whereas if the engine has less boundary friction, you would use a lower viscosity lubricant (again with a friction modifier). By looking at engine friction results for the conventional engine, it is possible to decrease engine friction by 10 or 20% by using the correct lubricant. There are a number of papers41-47 which the reader can refer to for more information on total engine friction calculations. To optimize power output from a high performance engine, it is necessary to choose a lubricant which gives the lowest possible friction. This entails choosing the lubricant viscosity which gives the lowest friction over the range of operating conditions appropriate for the engine, and choosing an optimum friction modifier for reducing friction in boundary lubricated contacts.
