Originally Posted By: TallPaul
Originally Posted By: 440Magnum
OBTW- here's the gauge installation on my Ram:
http://smg.beta.photobucket.com/user/440_Magnum/media/OP_0w20_4_7.mp4.html
Your gauge is working just like mine does hot. Idle is around 20 psi and rev to 4000+ and it goes to 85 psi. The big quesiton is what does yours go to on a cold morning? How cold does it get in your part of Texas? What is the cold start pressure and cold rev (but not to 4000) pressure?
By the way, nice rock steady idle at 600 rpm. Many EFI will idle at 800+ or did you have it in gear?
I've never seen that Ram top 100 psi, even when cold on either 0w20 or 5w20. I have to be pretty careful with the old big-blocks, because they'll easily peg the gauge when stone cold (40-wt oils and high-volume oil pumps).
The idle on the 4.7 Ram is interesting. If you have the AC off and the engine is fully warmed up, the idle will drop to 500 and sit there very solidly, in gear or out. Its almost disconcerting to be at a traffic light in winter and not be able to even hear it running. That video was done at the end of a 100+ degree day, so I'm sure the air was on! When the air is on, it won't go below 600 It wasn't in gear.
On a cold start, it will jump to 1500 RPM and is very slow to come down. But if you put it in gear, the idle drops quickly before the trans engages- the miracles of networked engine and transmission computers
