hello all. i just bought a 83 mercedes 300d. OM617.912 non turbo...
story is 2 owners ago decided if the oil would work in his honda hybrid it would work in the benz..
0-20w is what i was told. previous owner changed it to 15-40w ASAP.
oil pressure at idle is a bit low at .3-.5 bar when hot. when cold idle pressure is 1-1.1bar
any revs instantly brings the oil pressure back up and it will peg 3bar.
i want to drop the pan and check the strainer/pickup. the previous owner also changed the o-rings on the filter stem with no change.
i just bought some mobil 1 delvac 15-40 and a MANN bypass oil filter.
