Starting is normally intermittent duty but several FZJ80 users have had their starters continue to run after the key is released leading to a fire as the cable and starter overheat, a starter running until the battery is depleated or the starter melts would be continuous dutyquote:
Recheck your starter draw! Few starter draw more then 90 amps and this is for intermitent usage not continious. [/QB]
That 2KW figure comes from a Toyota manual; there was a 1.4KW and 2.2KW available in other years, also mentioned above a winch can draw 450A for a short periodquote:
Originally posted by RavenTai:
[QB]According to the NCF manual the starter is 2KW, I don’t know what voltage that is specified at but at nominal 12V that comes out to 166A, if it is rated at cranking voltage 10V? That comes out to 200A
You are right I could likely get away with smaller cable for the majority of situations but if I have to make cables I would like them to handle whatever may be thrown at them
