It seems that there are many comments throughout the threads that whenever someone wants to use M1 0w-30, they are told to mix half M1 0w-20 and half M1 0w-40.
I have learned that the reason for this is because, in comparison to M1 5w-30, the 0w-30 is only very slightly different, being just a little bit lower in viscosity as to give it a small advantage for cold starts.
So, I have to ask, is a mix of the 0w-20 and 0w-40 really any better than the actual 0w-30 (in regards to cold starts)?
And also, how do the add packs of those 3 oils compare to each other?
EDIT: I went ahead and added these from the PDS of each one for you to use in explaining, but I am still learning when it comes to all these numbers, so when you use them, could you explain them? Thanks:
Mobil 1 0W-20 AFE
SAE Grade 0W-20
Viscosity, @ 100ºC, cSt (ASTM D445) 8.7
Viscosity, @ 40ºC, cSt (ASTM D445) 44.8
Viscosity Index 173
Sulfated Ash, wt% (ASTM D874) 0.8
HTHS Viscosity, mPa•s @ 150ºC (ASTM D4683) 2.7
Phosphorous (ASTM D4951) 0.065
Flash Point, ºC (ASTM D92) 224
Total Base Number (ASTM D2896) 8.8
MRV @ -40ºC (ASTM D4684) 9200
Density @15.6ºC g/ml (ASTM D4052) 0.841
Mobil 1 0W-30 AFE
SAE Grade 0W-30
Viscosity @ 100ºC, cSt (ASTM D445) 10.9
Viscosity, @ 40ºC, cSt (ASTM D445) 62.9
Viscosity Index 166
Sulfated Ash, wt%, (ASTM D874) 0.9
HTHS Viscosity, mPa•s @ 150ºC (ASTM D4683) 3.0
Flash Point, ºC (ASTM D92) 226
Pour Point, ºC (ASTM D97) -50
Total Base Number (ASTM D2896) 9.1
MRV @ -40 ºC (ASTM D4684) 13,250
Density @15.6 ºC, g/ml (ASTM D4052) 0.842
Mobil 1 0W-40
Viscosity, cSt (ASTM D445)
@ 40º C 75
@ 100º C 13.5
Viscosity Index 185
MRV at -40ºC, cP (ASTM D4684) 31,000
HTHS Viscosity, mPa•s @ 150ºC, (ASTM D4683) 3.8
Total Base Number (ASTM D2896) 11.8
Sulfated Ash, wt% (ASTM D874) 1.3
Phosphorous, wt% (ASTM D4981) 0.1
Flash Point, ºC (ASTM D92) 230
Density @15.6 ºC, g/ml (ASTM D4052) 0.85
Mobil 1 0W-20 AFE
SAE Grade 0W-20
Viscosity Index 173
Mobil 1 0W-30 AFE
SAE Grade 0W-30
Viscosity Index 166
Mobil 1 0W-40
@ 40º C 75
@ 100º C 13.5
Viscosity Index 185
