Yes, for lugs I'd get the 25-250 ft lb. 1/2" drive torque wrench.
The reason being is you don't need massive precision, the prices aren't usually that much different, and you'll get a LONGER handle with the 25-250 torque wrench.
This gives you much greater leverage so you don't have to struggle to tighten the lug nuts.
And, because it is more in it's "range", it will take on less wear and tear as a beefier tool.
And if you bump into a friend with a small truck you can use it there too, or on axle nuts etc.
