I have a 1974 Honda XL100 with a 6V system out at the airport (gets occasional use) . The 6V lead acid batteries last about 1 month, and then it's impossible to get the thing to start. This is due to very poor voltage regulation (even with new components) that boils the battery dry, the small 6V battery and and the low chinese quality.
So like the post above, I went LifePO4. I simply purchased a 6V LiFe battery from Amazon and installed it. The claim was that the battery had it's own current limiting and cell balancing circuit. The battery was a replacement for a kid's toy car, and is limited to 10A discharge. Which the motorcycle headlight, taillight and ignition system easily exceeds when the engine is not running.... triggering the protection circuitry.
However, 6 months down the road, the battery still works, and the bike will start if I turn the headlight off. I'm not at all sure the battery is the right solution, but it's better than constantly purchasing chinese 6V lead acid batteries.
Amazon.com: TalentCell 6V 6Ah LiFePO4 Battery Pack LF060A1, 2000 Cycles Rechargeable Lithium Iron Phosphate Battery with Charger : Health & Household
www.amazon.com
