Here is the #2 UOA results for Lubrication Engineers LE8531, 5w30 Monolec Tetra-Syn
VOA numbers are the first set. Filter was a Pure One PL 10241, 48,133 miles on engine & truck, 3,020 miles on OCI. Don't flame me for the early change - had some really nice weather after what would be called harsh for North Texas winter and a couple of lengthy road trips coming up so I dropped the second run of this oil out and sent in a sample.
Lab comment - "Flagged data does not indicate an immediate need for maintenance action. Continue to observe the trend and monitor equipment and fluid conditions. FUEL DILUTION is at a MODERATE LEVEL. Base number is MODERATELY LOW. Lubricant and filter change acknowledged."
I was pleased the Sodium came way down along with the Copper in this sample. I was pretty sure the Sodium had come from a previous diet of Valvoline Synpower but I had no clue about the Copper. Anyway, while it skewed the 5K run trend I was hoping to hold to - here is another data point for LE8531 in a Toyot V6 1GR-FE. Please let me know your thoughts, thanks.
First UOA and comments are HERE
WEAR METALS (ppm)
Iron - 1,12,7
Chromium - 0,0,0
Nickel - 0,0,0
Aluminum - 1,4,3
Copper - 0,19,4
Lead - 1,0,0
Tin - 0,0,0
Cadmium - 0,0,0
Silver - 0,0,0
Vanadium - 0,0,0
CONTAMINANT METALS (ppm)
Silicon - 3,16,6
Sodium - 0,101,26
Potassium - 1,0,0
MULTI-SOURCE METALS (ppm)
Titanium - 0,0,0
Moly - 54,49,48
Antimony - 0,0.0
Manganese - 0,0,0
Lithium - 0,0,0
Boron - 1,0,0
ADDITIVE METALS (ppm)
Magnesium - 10,12,10
Calcium - 2190,2174,1892
Barium - 0,0,0
Phosphorus - 771,711,666
Zinc - 849,923,785
Water - < .1 - Hotplate, Viscosity @ 100 C - 10.4, 10.0, 9.5
Base Number - 7.29 mg KOH/g, 2.18, 3.07
Fuel dilution - 1.2% GC, 2.7% GC
WEAR METALS (ppm)
Iron - 1,12,7
Chromium - 0,0,0
Nickel - 0,0,0
Aluminum - 1,4,3
Copper - 0,19,4
Lead - 1,0,0
Tin - 0,0,0
Cadmium - 0,0,0
Silver - 0,0,0
Vanadium - 0,0,0
Silicon - 3,16,6
Sodium - 0,101,26
Potassium - 1,0,0
Titanium - 0,0,0
Moly - 54,49,48
Antimony - 0,0.0
Manganese - 0,0,0
Lithium - 0,0,0
Boron - 1,0,0
Barium - 0,0,0
Zinc - 849,923,785
