Originally Posted By: stower17
As for the comment for rear amber turn signals...
In vehicles that implement the turn signal with the brake light bulbs, if your brake light goes out chances are the bulb thats used for the turn signal also went out with it and you will know by the blinking speed of the turn signal. Its sort of like an integrated diagnostic system.
Cars with amber turn signals are more likely to be driving around with burnt out brake lights because the turn signal system still works properly...
You could argue which is safer, i have several GM cars from the early 2000's when they experimented with amber on nearly all their cars and only with those cars do people tell me my brake light is out because I had no idea.
And any responsible driver will check their lights periodically and replace any non-functioning bulbs, making this a moot point.
IMO, turn signals should never be allowed to share with brake lights. Even if the signals are red and separate, that's ok. But the shared lights just aren't visible enough in many situations.
