http://media.noria.com/ml/
Machinery Lubrication, July-Aug 2005
Article: Journal Bearings and their Lubrication, pg72
good article.
Current engine oils run 200-240F normally, and a typical 5w-30 is 10-11 cSt at 212F and 5w-20 is 7-8 cSt. Does the epa and cafe have us running at the minimum to get maximum fuel economy?
What would you define as moderate speed? Article makes mention of speed defined as rpm and irrelevant to shaft surface speeds. Does a car engine which runs 1500-3000 rpm qualify as moderate speed?
good article.
What caught my eye was *minimum* recommended is 13 cSt, with some designs allowing 7-8 cSt, at operating temperature.quote:
A generally accepted minimum viscosity of the oil at the operating temperature for journal bearings is 13 cSt, although some designs allow for an oil as thin as 7 or 8 cSt at the operating temperature.
The optimum viscosity at operating temperature is 22 to 35 cSt, for moderate-speed bearings if no shock loading occurs. The optimum viscosity may be as high as 95 cSt for low speed, or heavily loaded or shock-loaded journal bearings.
If the oil selected is too low in viscosity, heat will generate due to insufficient film thickness and some metal-to-metal contact will occur. If the oil is too high in viscosity, heat will again be generated, but due to internal fluid friction created within the oil. Selecting an oil which is too high in viscosity can also increase the likelihood of cavitation.
