I would like to have the front windows of my Jeep tinted. Is it necessary for the installer to remove the door panels? In BITOG fashion, I'm concerned about broken clips or other damage since I know they can be a bear to get off sometimes.
The installer I use does not pull the panels. Last one I had done was the driver/passenger side windows on our 19 Wrangler.I would like to have the front windows of my Jeep tinted. Is it necessary for the installer to remove the door panels? In BITOG fashion, I'm concerned about broken clips or other damage since I know they can be a bear to get off sometimes.
when I’ve done my own, I’ve had an easier time keeping the bottom free of dirt by pulling the panels.Installer preference. The guy who tinted my truck pulled the panels.
The shop that tinted my Prius did not, but they also cut the tint a bit short towards the bottom. I think pulling the panels allows for a cleaner install since you are less likely to get contamination towards the bottom. If the seals are tight, tucking can be more challenging.
