Originally Posted By: Jetronic
it's a rear blowout that would concern me more. What if it happens midcorner, say during a hillclimb, or descent?
In that case, you're probably better off feeding in some throttle and then gently backing off when the car is stable and controllable. Keeping a bit of throttle on can help retain stability when sliding. Cutting throttle suddenly is bad, especially if sliding or turning, as the sudden weight transfer can upset the vehicle and lead to snap oversteer.
Keep in mind, every vehicle responds differently, so what works in one vehicle may not work in another. Having an idea of how the vehicle behaves if you slide it around on a low-traction surface will give you some feel for what would work best to get it stable again after a blowout.
