I don't have any disagreement with that at all. In fact, thats a good summary and pretty much what the Fuchs guy said. With lower viscosity oils, your that much closer to that lower limit of 2.6 HT/HS. So what you need to do then, is have an oil analysis done, evaluate the wear and go from their. If your 3.2 HT/HS oil didn't shear a bit, your pretty safe with that oil. It's obviously not meeting the conditions that would stress it out.quote:
(1) performance reserve and (2) which oil, if stressed REALLY hard will continue to give the good UOAs. I do not believe that a 2.9cP or less 5W-20 (or any oil) has the reserve under serious stress that a 3.5+cP does. I think everyone should comes to grip with what do you want. If you don't need a significant reserve or don't push your card hard, the lesser HT/HS oil should be fine. If you do, etc etc I believe that most people are going to believe what they want to about this whole issue so each should do what he or she wants to and is comfortable with.
If I owned a Vette, or Audi, I would absolutely have a 3.5 HT/HS. With my Honda, I feel that a 3.2 HT/HS is a good margin of saftey compared to the 2.6 HT/HS that is in their now. BTW, M1 10w-30 EP is the oil I'm going with. Picked up 6 quarts.
